Giriş
Instructions on how remove the LCD display.
Neye ihtiyacın var
The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
Bir başkası bu kılavuzu tamamladı.
