Ana içeriğe geç
Sanyo VPC-T850 Shutter Button Replacement
Neye ihtiyacın var
    1. Sanyo VPC-T850 Shutter Button Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Sanyo VPC-T850 Shutter Button Replacement: adım 2, 1 resimden 1.
      • Locate the hatch found on the bottom of the camera.
      • Open the hatch by gripping the small notch and sliding it outwards.
      FixBot'a Sor
      Yorum Ekle
    3. Sanyo VPC-T850 Shutter Button Replacement: adım 3, 1 resimden 1.
      • Push the small, plastic arm out of the way to free the battery.
      • The battery is spring loaded and will pop out slightly when the arm is moved.
      FixBot'a Sor
      Yorum Ekle
    4. Sanyo VPC-T850 Shutter Button Replacement: adım 4, 1 resimden 1.
      • Pull the battery out of the camera and close the hatch.
      • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
      FixBot'a Sor
      Yorum Ekle
    1. Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: adım 5, 3 resimden 1. Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: adım 5, 3 resimden 2. Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: adım 5, 3 resimden 3.
      • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
      • Be sure to keep track of the side each screw comes from, as they come in different lengths.
      FixBot'a Sor
      Yorum Ekle
    2. Sanyo VPC-T850 Shutter Button Replacement: adım 6, 2 resimden 1. Sanyo VPC-T850 Shutter Button Replacement: adım 6, 2 resimden 2.
      • Orient the camera so the display is facing up.
      • Gently pull off the rear panel surrounding the display.
      • There are still three green wires connecting the panel to the rest of the camera.
      • Use your prying tool if you have difficulties removing the panel by hand.
      FixBot'a Sor
      Yorum Ekle
    3. Sanyo VPC-T850 Shutter Button Replacement: adım 7, 1 resimden 1.
      • Remove the eight black screws connecting the keypad circuit board to the rear panel.
      FixBot'a Sor
      Yorum Ekle
    4. Sanyo VPC-T850 Shutter Button Replacement: adım 8, 2 resimden 1. Sanyo VPC-T850 Shutter Button Replacement: adım 8, 2 resimden 2.
      • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
      FixBot'a Sor
      Yorum Ekle
    5. Sanyo VPC-T850 Shutter Button Replacement: adım 9, 1 resimden 1.
      • Flip the camera over so the lens is facing up.
      • Gently lift up the front panel to remove it from the rest of the camera.
      • Use your plastic opening tool if you have difficulties removing the panel by hand.
      FixBot'a Sor
      Yorum Ekle
    1. Sanyo VPC-T850 Shutter Button Replacement, Shutter Button: adım 10, 1 resimden 1.
      • Find the chrome framing located on the top of the camera.
      • The physical shutter button apparatus is directly attached to this frame.
      FixBot'a Sor
      Yorum Ekle
    2. Sanyo VPC-T850 Shutter Button Replacement: adım 11, 2 resimden 1. Sanyo VPC-T850 Shutter Button Replacement: adım 11, 2 resimden 2.
      • Remove the three black screws connecting the chrome frame to the camera.
      • Three screws are located toward the front, with the remaining one above the display.
      FixBot'a Sor
      Yorum Ekle
    3. Sanyo VPC-T850 Shutter Button Replacement: adım 12, 1 resimden 1.
      • Gently remove the loosened chrome frame and connected shutter button from the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
James Robinson
459 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 39
Her zaman: 684
