Ana içeriğe geç
Sanyo VPC-X1200 shutter assembly replacement
Neye ihtiyacın var
  1. Sanyo VPC-X1200 shutter assembly replacement, Back Case: adım 1, 3 resimden 1. Sanyo VPC-X1200 shutter assembly replacement, Back Case: adım 1, 3 resimden 2. Sanyo VPC-X1200 shutter assembly replacement, Back Case: adım 1, 3 resimden 3.
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Sanyo VPC-X1200 shutter assembly replacement: adım 2, 1 resimden 1.
    • Gently lift up the back cover and set aside.
  3. Sanyo VPC-X1200 shutter assembly replacement, LCD Screen: adım 3, 2 resimden 1. Sanyo VPC-X1200 shutter assembly replacement, LCD Screen: adım 3, 2 resimden 2.
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Sanyo VPC-X1200 shutter assembly replacement: adım 4, 2 resimden 1. Sanyo VPC-X1200 shutter assembly replacement: adım 4, 2 resimden 2.
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  5. Sanyo VPC-X1200 shutter assembly replacement, Button Plate: adım 5, 2 resimden 1. Sanyo VPC-X1200 shutter assembly replacement, Button Plate: adım 5, 2 resimden 2.
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  6. Sanyo VPC-X1200 shutter assembly replacement: adım 6, 2 resimden 1. Sanyo VPC-X1200 shutter assembly replacement: adım 6, 2 resimden 2.
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
  7. Sanyo VPC-X1200 shutter assembly replacement, Lens Unit: adım 7, 1 resimden 1.
    • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
    • One gate is black and another is white.
  8. Sanyo VPC-X1200 shutter assembly replacement: adım 8, 2 resimden 1. Sanyo VPC-X1200 shutter assembly replacement: adım 8, 2 resimden 2.
    • Remove the three silver screws.
    • Three 5.5mm screws
  9. Sanyo VPC-X1200 shutter assembly replacement: adım 9, 1 resimden 1.
    • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
Sonuç
Anthony Giardina
20 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-10, Maness Spring 2010 Cal Poly, Team 7-10, Maness Spring 2010 üyesi
CPSU-MANESS-S10S7G10
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 3,706
