Ana içeriğe geç
Sanyo-PM 8200 Motherboard Replacement
Neye ihtiyacın var
  1. Sanyo-PM 8200 Motherboard Replacement, Power Off Phone: adım 1, 1 resimden 1.
    • Power down the phone by holding down the red "end" button.
  2. Sanyo-PM 8200 Motherboard Replacement, Remove Old Battery: adım 2, 1 resimden 1.
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  3. Sanyo-PM 8200 Motherboard Replacement, Back Casing: adım 3, 1 resimden 1.
    • Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
  4. Sanyo-PM 8200 Motherboard Replacement: adım 4, 1 resimden 1.
    • Unscrew all four, 5mm Tri-Wing screws.
  5. Sanyo-PM 8200 Motherboard Replacement: adım 5, 2 resimden 1. Sanyo-PM 8200 Motherboard Replacement: adım 5, 2 resimden 2.
    • Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
    • This step may require extra force. But too much force could break the back casing.
    • Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
  6. Sanyo-PM 8200 Motherboard Replacement, Lift the Motherboard: adım 6, 1 resimden 1.
    • Gently lift up the motherboard. The keypad should now be exposed.
  7. Sanyo-PM 8200 Motherboard Replacement, Disconnect the Flex Ribbon: adım 7, 1 resimden 1.
    • Using tweezers, pull on the silver flex ribbon to disconnect it from the motherboard.
  8. Sanyo-PM 8200 Motherboard Replacement, Remove the Motherboard: adım 8, 1 resimden 1.
    • Remove the motherboard from the back of the phone.
Sonuç
Michaella
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Leahy Fall 2014 USF Tampa, Team 1-6, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S1G6
6 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 366
