Ana içeriğe geç
Satellite Pro R50-EC Keyboard Replacement
Neye ihtiyacın var
  1. Satellite Pro R50-EC Keyboard Replacement, Remove Battery and Screws: adım 1, 1 resimden 1.
    • Remove the battery
    • Remove every screw on the underside of the laptop chassis
  2. Satellite Pro R50-EC Keyboard Replacement, Prise open the chassis: adım 2, 3 resimden 1. Satellite Pro R50-EC Keyboard Replacement, Prise open the chassis: adım 2, 3 resimden 2. Satellite Pro R50-EC Keyboard Replacement, Prise open the chassis: adım 2, 3 resimden 3.
    • Once the screws are removed, using a flat tool, prise open the bottom of the case from the sides, following around the edges of the laptop until the bottom pulls off entirely.
  3. Satellite Pro R50-EC Keyboard Replacement, Internals Overview: adım 3, 2 resimden 1. Satellite Pro R50-EC Keyboard Replacement, Internals Overview: adım 3, 2 resimden 2.
    • Accessible replaceable parts include:
    • DVD Drive
    • Memory
    • LCD screen
    • SSD
    • WiFi Network card
    • CPU Fan
    • Keyboard
  4. Satellite Pro R50-EC Keyboard Replacement, Unplug required cables: adım 4, 3 resimden 1. Satellite Pro R50-EC Keyboard Replacement, Unplug required cables: adım 4, 3 resimden 2. Satellite Pro R50-EC Keyboard Replacement, Unplug required cables: adım 4, 3 resimden 3.
    • The keyboard cable is visible immediately on opening the laptop, but there's an annoying hitch: Toshiba have taped it to the metal underneath the motherboard.
    • As a result, the motherboard will need moving enough to pull off the tape.
    • So to start, disconnect all the ribbon cables that aren't free-moving on one end. These are:
    • 2 x USB controller cables
    • 1 x trackpad cable
    • 1 x Keyboard cable
    • 1 x audio ports controller cable
  5. Satellite Pro R50-EC Keyboard Replacement, Remove remaining screws: adım 5, 1 resimden 1.
    • Remove the following screws holding down the motherboard:
    • 2 x DVD bay screws
    • 1 x next to the WiFi card
    • 1 x CPU fan screw
    • 1 x next to the audio port controller
  6. Satellite Pro R50-EC Keyboard Replacement, Remove CPU fan: adım 6, 2 resimden 1. Satellite Pro R50-EC Keyboard Replacement, Remove CPU fan: adım 6, 2 resimden 2.
    • After removing the screw, disconnect the fan cable
    • Pull the fan clear of the motherboard so it can be moved further
  7. Satellite Pro R50-EC Keyboard Replacement, Behind the motherboard: adım 7, 1 resimden 1.
    • Lift the motherboard near the keyboard cable. It should now be free enough to see the tape holding the keyboard cable attached
    • Remove the tape
  8. Satellite Pro R50-EC Keyboard Replacement, Remove the Keyboard: adım 8, 3 resimden 1. Satellite Pro R50-EC Keyboard Replacement, Remove the Keyboard: adım 8, 3 resimden 2. Satellite Pro R50-EC Keyboard Replacement, Remove the Keyboard: adım 8, 3 resimden 3.
    • Carefully turn the laptop over
    • It may be easier to put the bottom of the chassis back on lightly so unsecured parts don't tip out.
    • The keyboard is clipped into the chassis. Starting at the sides of the keyboard, prise the keyboard out of the clips, moving around the keyboard until the keyboard easily pulls out.
    • Having removed the tape, the keyboard cable should now pull through from the rear easily.
Sonuç
Don't forget to replace the removed screws and reinsert all cables, including the CPU fan cable.
2 farklı kişi bu kılavuzu tamamladı.
Mars
262 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 35
Her zaman: 281
