Ana içeriğe geç
Scanner Head Replacement
Neye ihtiyacın var
    1. Scanner Head Replacement, Remove Back Panel: adım 1, 1 resimden 1.
      • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
      FixBot'a Sor
      Yorum Ekle
    2. Scanner Head Replacement, Remove Inner Back Pannel: adım 2, 2 resimden 1. Scanner Head Replacement, Remove Inner Back Pannel: adım 2, 2 resimden 2.
      • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
      FixBot'a Sor
      Yorum Ekle
    3. Scanner Head Replacement, Remove Upper Portion: adım 3, 2 resimden 1. Scanner Head Replacement, Remove Upper Portion: adım 3, 2 resimden 2.
      • Press down on the two plastic hinges to remove the upper portion of printer.
      FixBot'a Sor
      Yorum Ekle
    4. Scanner Head Replacement, Unplug Speaker Wire: adım 4, 1 resimden 1.
      • Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
      FixBot'a Sor
      Yorum Ekle
    5. Scanner Head Replacement, Removing Scanner Tray: adım 5, 2 resimden 1. Scanner Head Replacement, Removing Scanner Tray: adım 5, 2 resimden 2.
      • Rotate the printer so the paper tray is facing towards you.
      • Gently lift the scanner tray up and away from the printer.
      • Press the gray plastic tabs inward to release the tabs from the printer.
      FixBot'a Sor
      Yorum Ekle
    6. Scanner Head Replacement, Removing Scanner Tray - cont.: adım 6, 1 resimden 1.
      • Returning to the back of the printer, remove the scanner from the back hinges.
      • With pressure applied, the scanner will detach easily.
      FixBot'a Sor
      Yorum Ekle
    7. Scanner Head Replacement: adım 7, 1 resimden 1.
      • Gently grasp and unplug the two white ribbon cables from the printer body.
      • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
      FixBot'a Sor
      Yorum Ekle
    8. Scanner Head Replacement: adım 8, 1 resimden 1.
      • Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
      • Be sure to grasp the white connector and not to pull on the wires themselves.
      FixBot'a Sor
      Yorum Ekle
    9. Scanner Head Replacement, Detaching the Scanner Tray: adım 9, 1 resimden 1.
      • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
      FixBot'a Sor
      Yorum Ekle
    1. Scanner Head Replacement, Detaching the Scanner Head: adım 10, 2 resimden 1. Scanner Head Replacement, Detaching the Scanner Head: adım 10, 2 resimden 2.
      • Detach the white ribbon wire from the scanner head by pulling gently at the connection.
      FixBot'a Sor
      Yorum Ekle
    2. Scanner Head Replacement, Removing the Scanner Head: adım 11, 2 resimden 1. Scanner Head Replacement, Removing the Scanner Head: adım 11, 2 resimden 2.
      • Lift the gray drive belt from the black tab to disconnect the drive belt from the scanner head.
      • Remove the scanner head from the scanner by gently rotating and then lifting.
      FixBot'a Sor
      Yorum Ekle
    3. Scanner Head Replacement, Adding New Scanner Head: adım 12, 2 resimden 1. Scanner Head Replacement, Adding New Scanner Head: adım 12, 2 resimden 2.
      • Place the new scanner head in the scanner tray by fastening the drive belt into the black tab.
      • Make sure the tab on the outer portion of the gray drive belt is fastened.
      • Once the drive belt is secured, rotate the scanner head back into position.
      • Re-attach the white ribbon wire to the connection from Step 10.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mackenzie Billings
577 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-31, Maness Spring 2011 Cal Poly, Team 12-31, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G31
5 Üyeler
63 adet Kılavuz yazıldı
2Kılavuz Yorumları
Ok, but where do I purchase a new scanner head???
Nichelle King - Yanıt Paylaş
the step between 9 and 10 doesn't seem to make sense. it never established that the scanner head is broken...I couldn't identify where step 10 scanner head came up ...no where did it show the scanner between step 1 and step 9...Please offer an explanation...
by step 9 the scanner package had already removed...i m afraid I wont here from ifixit because the printer is about 20 years old.
winston ho - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 12,693
