Ana içeriğe geç
Sceptre X9 Komodo VII Speakers Replacement
Neye ihtiyacın var
  1. Sceptre X9 Komodo VII Speakers Replacement, Stand: adım 1, 1 resimden 1.
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Speakers Replacement: adım 2, 1 resimden 1.
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Speakers Replacement, Board Cover: adım 3, 1 resimden 1.
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Speakers Replacement: adım 4, 3 resimden 1. Sceptre X9 Komodo VII Speakers Replacement: adım 4, 3 resimden 2. Sceptre X9 Komodo VII Speakers Replacement: adım 4, 3 resimden 3.
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Speakers Replacement: adım 5, 2 resimden 1. Sceptre X9 Komodo VII Speakers Replacement: adım 5, 2 resimden 2.
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  6. Sceptre X9 Komodo VII Speakers Replacement, Speakers: adım 6, 1 resimden 1.
    • Disconnect the two connectors to the speakers by gently pulling on the hard plastic straight up.
  7. Sceptre X9 Komodo VII Speakers Replacement: adım 7, 1 resimden 1.
    • Carefully peel the tape from the board.
  8. Sceptre X9 Komodo VII Speakers Replacement: adım 8, 1 resimden 1.
    • Flip the monitor so the screen is facing you.
    • Using Phillips #2 screwdriver remove the four 6.25 mm screws securing the speakers:
  9. Sceptre X9 Komodo VII Speakers Replacement: adım 9, 1 resimden 1.
    • Carefully lift the speakers up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
Cal Poly, Team 16-56, Forte Fall 2012 Cal Poly, Team 16-56, Forte Fall 2012 üyesi
CPSU-FORTE-F12S16G56
5 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 421
