Neye ihtiyacın var
Place the monitor face down.
Remove the four 11.5mm screws with a #2 Phillips screwdriver.
Remove the stand by pulling it out.
Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
Disconnect the multi-pin connector at the top of the board by firmly grasping the connector and pulling to the side.
Disconnect the multi-pin connector that runs between the video motherboard and the power supply motherboard. Firmly grasp the connector and pull straight up.
