Ana içeriğe geç
Schwinn Tourist Inner Tube Replacement
Neye ihtiyacın var
  1. Schwinn Tourist Inner Tube Replacement, Front Inner Tube: adım 1, 1 resimden 1.
    • Flip the bicycle upside down.
    • By flipping the bicycle upside down it will offer additional support by being able to stand up by itself.
  2. Schwinn Tourist Inner Tube Replacement, Loosen The Brakes: adım 2, 1 resimden 1.
    • Apply pressure to both sides of the brake arm with one hand and lift the metal brake cable from the brake caliper.
    • By releasing the brake cable from the brake caliper, it will loosen the brake pads by the tire.
  3. Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: adım 3, 2 resimden 1. Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: adım 3, 2 resimden 2.
    • Push the quick release lever outwards towards your body.
    • While holding the other end of the quick release lever, rotate the lever counter-clockwise until it is loose.
  4. Schwinn Tourist Inner Tube Replacement, Remove Tire: adım 4, 1 resimden 1.
    • Lift the tire to remove it from the bicycle.
  5. Schwinn Tourist Inner Tube Replacement, Inserting The Tire Lever: adım 5, 1 resimden 1.
    • Insert the flat end of the tire lever between the inside wall of the tire and the outside of the rim.
    • Attach the other end of the tire lever to the nearest spoke on the rim.
  6. Schwinn Tourist Inner Tube Replacement, Insering Second Tire Lever: adım 6, 1 resimden 1.
    • Insert a second tire lever next to the first lever to create leverage for releasing the tire from the rim.
  7. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: adım 7, 1 resimden 1.
    • Leave the first lever in place. Slide the second lever against the outside edge of the rim until one side of the tire is off of the rim.
  8. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: adım 8, 1 resimden 1.
    • Reattach the the first lever to the other side of the tire and repeat steps 4-7 to remove tire completely from rim.
  9. Schwinn Tourist Inner Tube Replacement, Remove the Valve Stem: adım 9, 1 resimden 1.
    • Push the valve stem upwards through the hole in the rim.
  10. Schwinn Tourist Inner Tube Replacement, Finished: adım 10, 1 resimden 1.
    • Once valve stem is pushed, pull the inner tube until it is completely removed from the rim.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Quandre Mebane
149 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-22, Donnelly Fall 2014 USF Tampa, Team 1-22, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G22
1 Üye
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 5,238
