Ana içeriğe geç
Screen Door Closer Replacement
Neye ihtiyacın var
  1. Screen Door Closer Replacement, Door closer: adım 1, 1 resimden 1.
    • Make sure the door is completely closed. push up from the bottom to remove the pin from the bracket that connects the barrel to the door frame and release the door closer barrel.
    • If the pin is under too much tension, open the door about an inch and slide the open clip (metal washer that keeps the screen door open) against the barrel and repeat step 1.
  2. Screen Door Closer Replacement: adım 2, 1 resimden 1.
    • After removing the pin, the closer barrel can be removed.
  3. Screen Door Closer Replacement: adım 3, 1 resimden 1.
    • Loosen the screws from the bracket on the screen door to remove the bracket.
  4. Screen Door Closer Replacement: adım 4, 1 resimden 1.
    • Loosen the screws from the door jamb bracket and remove.
  5. Screen Door Closer Replacement: adım 5, 1 resimden 1.
    • Attach the new bracket to the door jamb with provided screws.
  6. Screen Door Closer Replacement: adım 6, 1 resimden 1.
    • Slide the new clip (metal washer that was provided with the door closer) on the door closer barrel with the dented side facing inwards (as shown in photo).
  7. Screen Door Closer Replacement: adım 7, 1 resimden 1.
    • Insert the pin into the closer barrel and the jamb bracket.
  8. Screen Door Closer Replacement: adım 8, 1 resimden 1.
    • Install new bracket onto screen door. Keep screws slightly loose.
  9. Screen Door Closer Replacement: adım 9, 1 resimden 1.
    • Slip the other pin into the barrel and the bracket.
  10. Screen Door Closer Replacement: adım 10, 1 resimden 1.
    • Slide the bracket away from the barrel until there is no slack. Tighten screws on the bracket.
  11. Screen Door Closer Replacement: adım 11, 1 resimden 1.
    • Test the door and if there are any issues (i.e. door closing too fast or too slow). Make necessary adjustments to the tension screw.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Shafaq Hasan
122 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 19
Son 30 gün: 98
Her zaman: 9,793
