Giriş
Does your screen door no longer close gently like it used to? Does it ever close behind you on
your ankle before you have both feet in the door? Not only can this be annoying but it can also
hurt! This a simple fast fix on how to replace your old screen door closer with a new one.
Neye ihtiyacın var
Make sure the door is completely closed. push up from the bottom to remove the pin from the bracket that connects the barrel to the door frame and release the door closer barrel.
2 farklı kişi bu kılavuzu tamamladı.
