Giriş
Disassembly instructions to get at the hard drive of a Seagate FreeAgent 880GB drive
Neye ihtiyacın var
This guide holds true for most all FreeAgentGo drives that have this body style
The first thing you'll need to do is get a spudger of some sort and get underneath an edge. It doesn't expressly matter which, I found starting at the front corner the the easiest.
Work your way all the way around the edges, the cover is being held in place by rubber cement-like glue.
8 farklı kişi bu kılavuzu tamamladı.
