Ana içeriğe geç
Sears Craftsman 315.109020 Motor Replacement
Neye ihtiyacın var
  1. Sears Craftsman 315.109020 Motor Replacement, Motor: adım 1, 2 resimden 1. Sears Craftsman 315.109020 Motor Replacement, Motor: adım 1, 2 resimden 2.
    • To ensure that you do not get grease and dirt on your table or floor, lay a towel down before you begin working.
    • The grease from the circular saw can stain your towel so a dirty towel or work rag is recommended.
  2. Sears Craftsman 315.109020 Motor Replacement: adım 2, 3 resimden 1. Sears Craftsman 315.109020 Motor Replacement: adım 2, 3 resimden 2. Sears Craftsman 315.109020 Motor Replacement: adım 2, 3 resimden 3.
    • With your Phillips screwdriver, unscrew all 7 of the 20 mm screws on the handle of the circular saw.
    • There is one 25 mm screw that goes in the hole circled in red.
    • Unscrew the forked screw head
    • Lift off the top half of the handle.
  3. Sears Craftsman 315.109020 Motor Replacement: adım 3, 2 resimden 1. Sears Craftsman 315.109020 Motor Replacement: adım 3, 2 resimden 2.
    • Unscrew the two wide-head 20 mm screws holding the remaining half of the handle to the motor.
    • Remove the remaining half of the handle from the motor by lifting it over the screw that is keeping it in place.
  4. Sears Craftsman 315.109020 Motor Replacement: adım 4, 3 resimden 1. Sears Craftsman 315.109020 Motor Replacement: adım 4, 3 resimden 2. Sears Craftsman 315.109020 Motor Replacement: adım 4, 3 resimden 3.
    • Using a crescent wrench, unscrew the hex washer head screw that is holding the blade in place.
    • Lift the blade over the internally threaded screw and pull it off of the saw.
    • If the hex washer head screw rotates but does not loosen or if the whole blade rotates as you turn your wrench, giving the wrench a quick jerk should loosen the screw.
  5. Sears Craftsman 315.109020 Motor Replacement: adım 5, 2 resimden 1. Sears Craftsman 315.109020 Motor Replacement: adım 5, 2 resimden 2.
    • Remove the blade cover by applying upward pressure until it unsnaps from the washer.
    • The blade cover will come off easier if it is facing away from the rest of the saw (see second picture).
  6. Sears Craftsman 315.109020 Motor Replacement: adım 6, 2 resimden 1. Sears Craftsman 315.109020 Motor Replacement: adım 6, 2 resimden 2.
    • Unscrew the 70 mm screw that is inside the black tube (see first picture).
    • Unscrew the five screws as highlighted in the second picture. The bottom left is a 70 mm screw and the other four are 20 mm screws.
    • Unscrewing the remaining four 20 mm screws are unnecessary unless you wish to repair or replace the cogs in the saw.
  7. Sears Craftsman 315.109020 Motor Replacement: adım 7, 2 resimden 1. Sears Craftsman 315.109020 Motor Replacement: adım 7, 2 resimden 2.
    • The motor will now be loose and you should be able to twist the motor in a counter-clockwise direction until it is able to be pulled off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Blake Avant
218 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-4, Green Fall 2015 Cal Poly, Team 17-4, Green Fall 2015 üyesi
CPSU-GREEN-F15S17G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 377
