Ana içeriğe geç
Sega CD Plastic Housing Removal
Neye ihtiyacın var
  1. Sega CD Plastic Housing Removal, Sega CD Plastic Housing Removal: adım 1, 2 resimden 1. Sega CD Plastic Housing Removal, Sega CD Plastic Housing Removal: adım 1, 2 resimden 2.
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD Plastic Housing Removal: adım 2, 1 resimden 1.
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD Plastic Housing Removal: adım 3, 1 resimden 1.
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD Plastic Housing Removal: adım 4, 1 resimden 1.
    • Lift from the left side to remove the top of the case.
  5. Sega CD Plastic Housing Removal: adım 5, 1 resimden 1.
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD Plastic Housing Removal: adım 6, 1 resimden 1.
    • Lift the top of the case to remove the cover.
  7. Sega CD Plastic Housing Removal: adım 7, 1 resimden 1.
    • Remove the faceplate by pulling it up, then out.
Sonuç
To reassemble the device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Ryan Kotzebue
271 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-14, Maness Fall 2010 Cal Poly, Team 5-14, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G14
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 4,883
