Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the console over on its back.
Take note of your model number, in case replacement parts are needed.
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
Turn the console right side up.
Remove the top cover by gently lifting the upper portion of the console.
Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
Remove the four 14mm Philips #02 screws located on the controller board.
Disconnect the white fan header from the controller port.
Remove the controller board by lifting it up from the controller port.
Flip the controller board on its underside so that the solder joints are exposed.
Remove the F1 fuse by using the soldering iron and desoldering wick.
The F1 fuse is clearly indicated on the topside of the controller board.
Insert and solder the parallel 10 ohm 1/4 watt resistors to the F1 socket.
6 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Hello, Darren. I am having the utmost difficulty doing this with two 1/4 watt resistors, as you have demonstrated. I have three dreamcast systems, I would like to repair (all with a bad controller port.) What would be the chance that I could send you the ports, packs of resistors and and solder and pay you to do this to all of them?
I would even be willing to give you two of them! I just want one working system!
djresree -
I need this board, were do I find one?
