Giriş
A guide to remove the intake fan from the Sega Dreamcast.
Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
Yorum Ekle
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Yorum Ekle
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
Yorum Ekle
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
Yorum Ekle
Remove the white fan header by gently pulling it away from from the controller port.
  • Remove the white fan header by gently pulling it away from from the controller port.
  • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
Yorum Ekle
Remove the two 8.5mm Philips #00 screws from the fan bracket.
  • Remove the two 8.5mm Philips #00 screws from the fan bracket.
Yorum Ekle
Remove the two 17.5mm Philips #00 screws from the fan bracket. Remove the fan from the bracket.
  • Remove the two 17.5mm Philips #00 screws from the fan bracket.
  • Remove the fan from the bracket.
Yorum Ekle
Sonuç
2 başka kişi bu kılavuzu tamamladı.
wkwong
381 İtibar
13 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 üyesi
CPSU-REGAN-F09S5G1
5 Üye
23 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 6
Son 30 Gün: 20
Tüm Zamanlar: 5,969
