Ana içeriğe geç
Sega Dreamcast Fan Replacement
Neye ihtiyacın var
  1. Sega Dreamcast Fan Replacement, Expansion Bay: adım 1, 2 resimden 1. Sega Dreamcast Fan Replacement, Expansion Bay: adım 1, 2 resimden 2.
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Fan Replacement: adım 2, 3 resimden 1. Sega Dreamcast Fan Replacement: adım 2, 3 resimden 2. Sega Dreamcast Fan Replacement: adım 2, 3 resimden 3.
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Fan Replacement, Top Cover: adım 3, 1 resimden 1.
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Fan Replacement: adım 4, 1 resimden 1.
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Fan Replacement, Fan: adım 5, 1 resimden 1.
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
  6. Sega Dreamcast Fan Replacement: adım 6, 1 resimden 1.
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
  7. Sega Dreamcast Fan Replacement: adım 7, 2 resimden 1. Sega Dreamcast Fan Replacement: adım 7, 2 resimden 2.
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
  8. Sega Dreamcast Fan Replacement, Fan: adım 8, 2 resimden 1. Sega Dreamcast Fan Replacement, Fan: adım 8, 2 resimden 2.
    • Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws.
    • Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Thorr686
500 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 üyesi
CPSU-REGAN-F09S5G1
5 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 19,880
