Giriş
This guide details how to replace a malfunctioning fan in the Sega Dreamcast.
Be sure to replace the fan with one corresponding to your Model Number. Refer to the Top Cover Disassembly Guide for instructions on where to find your model number.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Flip the console over on its back.
Take note of your model number, in case replacement parts are needed.
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
Remove the white fan header by gently pulling it away from from the controller port.
Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws.
Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
4 farklı kişi bu kılavuzu tamamladı.
2 Yorum
My laptop Fan is the same, the model is HP 6465b. it creates some noise despite of cleanliness. How i can Fix it?
I would like to share my thoughts about your piece of words. These are really amazing please keep writing because your words really helping out to improve my knowledge & help me to fix this. Really
