Ana içeriğe geç
Sega Dreamcast GD-ROM Replacement
Neye ihtiyacın var
  1. Sega Dreamcast GD-ROM Replacement, Expansion Bay: adım 1, 2 resimden 1. Sega Dreamcast GD-ROM Replacement, Expansion Bay: adım 1, 2 resimden 2.
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast GD-ROM Replacement: adım 2, 3 resimden 1. Sega Dreamcast GD-ROM Replacement: adım 2, 3 resimden 2. Sega Dreamcast GD-ROM Replacement: adım 2, 3 resimden 3.
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast GD-ROM Replacement, Top Cover: adım 3, 1 resimden 1.
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast GD-ROM Replacement: adım 4, 1 resimden 1.
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast GD-ROM Replacement, GD-ROM: adım 5, 2 resimden 1. Sega Dreamcast GD-ROM Replacement, GD-ROM: adım 5, 2 resimden 2.
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  6. Sega Dreamcast GD-ROM Replacement: adım 6, 2 resimden 1. Sega Dreamcast GD-ROM Replacement: adım 6, 2 resimden 2.
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  7. Sega Dreamcast GD-ROM Replacement: adım 7, 2 resimden 1. Sega Dreamcast GD-ROM Replacement: adım 7, 2 resimden 2.
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  8. Sega Dreamcast GD-ROM Replacement: adım 8, 2 resimden 1. Sega Dreamcast GD-ROM Replacement: adım 8, 2 resimden 2.
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  9. Sega Dreamcast GD-ROM Replacement, GD-ROM: adım 9, 2 resimden 1. Sega Dreamcast GD-ROM Replacement, GD-ROM: adım 9, 2 resimden 2.
    • Replace the bad GD-ROM drive with a functional one.
  10. Sega Dreamcast GD-ROM Replacement: adım 10, 2 resimden 1. Sega Dreamcast GD-ROM Replacement: adım 10, 2 resimden 2.
    • Secure the new GD-ROM drive to the console with the Philips #2 screws.
  11. Sega Dreamcast GD-ROM Replacement: adım 11, 3 resimden 1. Sega Dreamcast GD-ROM Replacement: adım 11, 3 resimden 2. Sega Dreamcast GD-ROM Replacement: adım 11, 3 resimden 3.
    • Connect the three GD-ROM cables to the logic board.
    • Connect the GD-ROM data ribbon to the logic board.
Bitiş Çizgisi
10 farklı kişi bu kılavuzu tamamladı.
Thorr686
472 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 üyesi
CPSU-REGAN-F09S5G1
5 Üyeler
21 adet Kılavuz yazıldı
Bir Yorum
If only it was that simple Sega screwed U.K gamers over with the fact we have to buy totally new consoles due to the wires of the disk drive being soldered in rather than clipped in.
Anthony Salmon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 164
Her zaman: 33,450
