Giriş
A guide to remove the GD-ROM from the Sega Dreamcast.
Problem with this guide: The photos incorrectly show the power supply has been removed.
Parçalar
Hiçbir parçaya gerek yok.
Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
Yorum Ekle
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Yorum Ekle
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
Yorum Ekle
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
Yorum Ekle
Detach the orange cable  by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board. Detach the orange cable  by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
Yorum Ekle
Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board. Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
Yorum Ekle
Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket. The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
  • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
Yorum Ekle
When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base. Remove the GD-ROM by gently lifting it from its base.
  • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
  • Remove the GD-ROM by gently lifting it from its base.
Yorum Ekle
Sonuç
7 başka kişi bu kılavuzu tamamladı.
wkwong
381 İtibar
13 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 üyesi
CPSU-REGAN-F09S5G1
5 Üyeler
23 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 Gün: 28
Son 30 Gün: 84
Tüm Zamanlar: 14,561
