Ana içeriğe geç
Sega Dreamcast Logic Board Replacement
Neye ihtiyacın var
  1. Sega Dreamcast Logic Board Replacement, Expansion Bay: adım 1, 2 resimden 1. Sega Dreamcast Logic Board Replacement, Expansion Bay: adım 1, 2 resimden 2.
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Logic Board Replacement: adım 2, 3 resimden 1. Sega Dreamcast Logic Board Replacement: adım 2, 3 resimden 2. Sega Dreamcast Logic Board Replacement: adım 2, 3 resimden 3.
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Logic Board Replacement, Top Cover: adım 3, 1 resimden 1.
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Logic Board Replacement: adım 4, 1 resimden 1.
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Logic Board Replacement, Power Block (Power Supply): adım 5, 2 resimden 1. Sega Dreamcast Logic Board Replacement, Power Block (Power Supply): adım 5, 2 resimden 2.
    • Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working.
    • Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
  6. Sega Dreamcast Logic Board Replacement: adım 6, 1 resimden 1.
    • Remove the two 10mm Philips #02 screws that are fastened to the power block.
  7. Sega Dreamcast Logic Board Replacement: adım 7, 2 resimden 1. Sega Dreamcast Logic Board Replacement: adım 7, 2 resimden 2.
    • Do not bend the male pin header between the mounted head when you remove the power supply from the chassis.
    • Remove the power board by using both hands to gently lift the power board away from the console.
  8. Sega Dreamcast Logic Board Replacement: adım 8, 1 resimden 1.
    • Remove the clear plastic film that is tucked between the power supply and the chassis.
  9. Sega Dreamcast Logic Board Replacement, Controller Port: adım 9, 2 resimden 1. Sega Dreamcast Logic Board Replacement, Controller Port: adım 9, 2 resimden 2.
    • Be gentle with the white controller cable as it can be a bit fragile.
    • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
  10. Sega Dreamcast Logic Board Replacement: adım 10, 2 resimden 1. Sega Dreamcast Logic Board Replacement: adım 10, 2 resimden 2.
    • Remove the four 14mm Philips #02 screws located on the controller board.
  11. Sega Dreamcast Logic Board Replacement: adım 11, 2 resimden 1. Sega Dreamcast Logic Board Replacement: adım 11, 2 resimden 2.
    • Disconnect the white fan header from the controller port.
  12. Sega Dreamcast Logic Board Replacement: adım 12, 2 resimden 1. Sega Dreamcast Logic Board Replacement: adım 12, 2 resimden 2.
    • Remove the controller board by lifting it up from the controller port.
  13. Sega Dreamcast Logic Board Replacement, GD-ROM: adım 13, 2 resimden 1. Sega Dreamcast Logic Board Replacement, GD-ROM: adım 13, 2 resimden 2.
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  14. Sega Dreamcast Logic Board Replacement: adım 14, 2 resimden 1. Sega Dreamcast Logic Board Replacement: adım 14, 2 resimden 2.
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  15. Sega Dreamcast Logic Board Replacement: adım 15, 2 resimden 1. Sega Dreamcast Logic Board Replacement: adım 15, 2 resimden 2.
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  16. Sega Dreamcast Logic Board Replacement: adım 16, 2 resimden 1. Sega Dreamcast Logic Board Replacement: adım 16, 2 resimden 2.
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  17. Sega Dreamcast Logic Board Replacement, Fan: adım 17, 1 resimden 1.
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
  18. Sega Dreamcast Logic Board Replacement: adım 18, 1 resimden 1.
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
  19. Sega Dreamcast Logic Board Replacement: adım 19, 2 resimden 1. Sega Dreamcast Logic Board Replacement: adım 19, 2 resimden 2.
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
  20. Sega Dreamcast Logic Board Replacement, Logic Board: adım 20, 3 resimden 1. Sega Dreamcast Logic Board Replacement, Logic Board: adım 20, 3 resimden 2. Sega Dreamcast Logic Board Replacement, Logic Board: adım 20, 3 resimden 3.
    • Remove the five 10mm Philips #02 screws from left side of the logic board cover.
    • Remove the three black 12mm Philips #02 screws from the right side of the logic board cover.
  21. Sega Dreamcast Logic Board Replacement: adım 21, 3 resimden 1. Sega Dreamcast Logic Board Replacement: adım 21, 3 resimden 2. Sega Dreamcast Logic Board Replacement: adım 21, 3 resimden 3.
    • Lift the metal cover from the console.
  22. Sega Dreamcast Logic Board Replacement: adım 22, 2 resimden 1. Sega Dreamcast Logic Board Replacement: adım 22, 2 resimden 2.
    • Before handing the logic board, you may want to use a grounding strap to protect the device from static charge. If you do not have a grounding strip, you may ground yourself by touching a large metallic object.
    • Remove the logic board and set the logic board on an anti-static surface.
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
wkwong
557 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 üyesi
CPSU-REGAN-F09S5G1
5 Üyeler
21 adet Kılavuz yazıldı
1Rehber Yorum
helpful but my dreamcast had a different logic board and as well as fan and gd-rom so keep that in mind if u see something different in your unit
Nickolas Wilcox - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 37
Son 30 gün: 177
Her zaman: 25,211
