Giriş
A guide to remove the Logic Board from the Sega Dreamcast.
Neye ihtiyacın var
Flip the console over on its back.
Take note of your model number, in case replacement parts are needed.
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
Note that on some Dreamcasts the power board (on the left) overhangs slightly over the controller board, meaning one must also remove the power board at this stage. This is relatively straightforward, fortunately. Remove a screw each at the top left of the power board and at the bottom left of the power board, remove the white clip at the top left, pop out the white clip on the left of the power board and lift the power board out from the front where you have the white block containing eight pins that connect the power board to the sub board. Then proceed per the rest of this guide. Hope this helps.
Disconnect the white fan header from the controller port.
Perhaps list the battery type an battery holders that allow for easy replacement in the future?
Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
Remove the white fan header by gently pulling it away from from the controller port.
Remove the five 10mm Philips #02 screws from left side of the logic board cover.
Remove the three black 12mm Philips #02 screws from the right side of the logic board cover.
21 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
helpful but my dreamcast had a different logic board and as well as fan and gd-rom so keep that in mind if u see something different in your unit
