Ana içeriğe geç
Sega Dreamcast Power Supply Replacement
Neye ihtiyacın var
  1. Sega Dreamcast Power Supply Replacement, Expansion Bay: adım 1, 2 resimden 1. Sega Dreamcast Power Supply Replacement, Expansion Bay: adım 1, 2 resimden 2.
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Power Supply Replacement: adım 2, 3 resimden 1. Sega Dreamcast Power Supply Replacement: adım 2, 3 resimden 2. Sega Dreamcast Power Supply Replacement: adım 2, 3 resimden 3.
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Power Supply Replacement, Top Cover: adım 3, 1 resimden 1.
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Power Supply Replacement: adım 4, 1 resimden 1.
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Power Supply Replacement, Power Supply: adım 5, 2 resimden 1. Sega Dreamcast Power Supply Replacement, Power Supply: adım 5, 2 resimden 2.
    • Unplug the device from the outlet. If you have just powered off the system, allow a few minutes for the capacitors to discharge before you begin working.
    • Remove the white female pin head by pinching and lifting directly up on the harness.
    • Remove the two Philips #02 screws from the board.
    • Remove the power board. Using both hands, gently lift the power board away from the console without damaging the male pin head
  6. Sega Dreamcast Power Supply Replacement: adım 6, 2 resimden 1. Sega Dreamcast Power Supply Replacement: adım 6, 2 resimden 2.
    • Remove the unit. Carefully remove the power board from the console by lightly grasping the board by the edge and lifting directly upward.
    • Remove the two 10mm #02 Philips screws to detach the switch module from the console.
    • Purchase a replacement power board.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jacks216
103 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 üyesi
CPSU-REGAN-F09S5G1
5 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 28
Son 30 gün: 85
Her zaman: 18,008
