Ana içeriğe geç
Sega Game Gear Case Replacement
Neye ihtiyacın var
  1. Sega Game Gear Case Replacement, Battery: adım 1, 1 resimden 1.
    • Place your device upside down and locate the two battery compartments.
    FixBot'a Sor
    Yorum Ekle
  2. Sega Game Gear Case Replacement: adım 2, 1 resimden 1.
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
    FixBot'a Sor
    Yorum Ekle
  3. Sega Game Gear Case Replacement, Case: adım 3, 1 resimden 1.
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
    FixBot'a Sor
    Yorum Ekle
  4. Sega Game Gear Case Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to take all other screws out.
    FixBot'a Sor
    Yorum Ekle
  5. Sega Game Gear Case Replacement: adım 5, 2 resimden 1. Sega Game Gear Case Replacement: adım 5, 2 resimden 2.
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
    FixBot'a Sor
    Yorum Ekle
  6. Sega Game Gear Case Replacement: adım 6, 3 resimden 1. Sega Game Gear Case Replacement: adım 6, 3 resimden 2. Sega Game Gear Case Replacement: adım 6, 3 resimden 3.
    • Carefully unplug the 2 white-tipped connectors on the top cover.
    FixBot'a Sor
    Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Lauren Thurston
506 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 28-33, Regan Spring 2010 Cal Poly, Team 28-33, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G33
5 Üyeler
20 adet Kılavuz yazıldı
1Rehber Yorum
Is this guide made to help replacing the Game Gear shell? Almost doesn't seem like a thorough guide, I'm still seeing screws on the motherboard in the last photo, I assume those get taken out too?
Alex Tomalty - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 21
Son 30 gün: 125
Her zaman: 22,596
