Ana içeriğe geç
Sega Game Gear Speakers Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sega Game Gear Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Speakers Replacement: adım 2, 1 resimden 1.
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Speakers Replacement, Case: adım 3, 1 resimden 1.
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Speakers Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Speakers Replacement: adım 5, 2 resimden 1. Sega Game Gear Speakers Replacement: adım 5, 2 resimden 2.
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Speakers Replacement: adım 6, 3 resimden 1. Sega Game Gear Speakers Replacement: adım 6, 3 resimden 2. Sega Game Gear Speakers Replacement: adım 6, 3 resimden 3.
    • Carefully unplug the 2 white-tipped connectors on the top cover.
  7. Sega Game Gear Speakers Replacement, Speakers: adım 7, 1 resimden 1.
    • Unscrew the 8 Phillips screws from the logic board.
  8. Sega Game Gear Speakers Replacement: adım 8, 1 resimden 1.
    • Slide the logic board out from under the circular black fastener at the top-left corner of the case.
  9. Sega Game Gear Speakers Replacement: adım 9, 2 resimden 1. Sega Game Gear Speakers Replacement: adım 9, 2 resimden 2.
    • Removing the plastic holding the speaker to the case may permanently detach the speaker.
    • The plastic at these three locations is melted to the plastic. Pry off with caution.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lauren Thurston
493 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 28-33, Regan Spring 2010 Cal Poly, Team 28-33, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G33
5 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 47
Her zaman: 12,691
