Ana içeriğe geç
Sega Genesis Flashback Controller Batteries Replacement
Neye ihtiyacın var
  1. Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: adım 1, 2 resimden 1. Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: adım 1, 2 resimden 2.
    • Using a Phillips #000 screwdriver, unscrew the single screw located on the battery cover. Remove the battery cover and set it aside.
    • The screw does not detach from the battery cover, so do not attempt to separate them.
    FixBot'a Sor
    Yorum Ekle
  2. Sega Genesis Flashback Controller Batteries Replacement: adım 2, 2 resimden 1. Sega Genesis Flashback Controller Batteries Replacement: adım 2, 2 resimden 2.
    • If batteries are in the battery slots and need to be replaced, then remove the old batteries by pressing them in and compressing the spring until there is enough space to take them out.
    • Insert two fresh batteries into each one of the slots by pushing the indicated negative end of the battery against the spring.
    • All AAA batteries have “+” and “-” symbols on each end of the batteries to denote the positive and negative ends.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Omar Shorab
261 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018 üyesi
CPSU-MANESS-S18S24G12
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
any idea where i can find a schematic for the contoller board. I just bought one of these second hand and the wireless controller won’t connect to the system. I took it apart and it’s missing a small resistor.
Scott Phaneuf - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 3,328
