Ana içeriğe geç
Sega Genesis Motherboard Replacement
Neye ihtiyacın var
  1. Sega Genesis Motherboard Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Sega Genesis Motherboard Replacement: adım 2, 1 resimden 1.
    • Flip the Sega Genesis upright.
    FixBot'a Sor
    Yorum Ekle
  3. Sega Genesis Motherboard Replacement: adım 3, 1 resimden 1.
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
    FixBot'a Sor
    Yorum Ekle
  4. Sega Genesis Motherboard Replacement: adım 4, 1 resimden 1.
    • Bend out the LED leads into vertical positions.
    FixBot'a Sor
    Yorum Ekle
  5. Sega Genesis Motherboard Replacement: adım 5, 1 resimden 1.
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
    FixBot'a Sor
    Yorum Ekle
  6. Sega Genesis Motherboard Replacement: adım 6, 1 resimden 1.
    • Separate the main board from the outer case.
    FixBot'a Sor
    Yorum Ekle
  7. Sega Genesis Motherboard Replacement, Motherboard: adım 7, 1 resimden 1.
    • Remove single black screw from the outside of the bottom cover, using a Philips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Sega Genesis Motherboard Replacement: adım 8, 1 resimden 1.
    • Using a Philips screwdriver, remove 11 screws securing silver casing.
    FixBot'a Sor
    Yorum Ekle
  9. Sega Genesis Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove silver case.
    FixBot'a Sor
    Yorum Ekle
  10. Sega Genesis Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove single golden screw on motherboard using Philips screwdriver.
    • Note: Push headphone jack to the side.
    FixBot'a Sor
    Yorum Ekle
  11. Sega Genesis Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove two black screws on the left and right sides of the cartridge slot.
    FixBot'a Sor
    Yorum Ekle
  12. Sega Genesis Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove motherboard.
    FixBot'a Sor
    Yorum Ekle
  13. Sega Genesis Motherboard Replacement: adım 13, 1 resimden 1.
    • Re-install new motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Erik Bjornstrom
852 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G29
4 Üyeler
23 adet Kılavuz yazıldı
1Rehber Yorum
When i played game 10 or 5 min
My consol hanged
And so need rest
What problem ?
Mojtaba Nikoei - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 54
Son 30 gün: 271
Her zaman: 39,272
