Ana içeriğe geç
Sega Genesis Outer Case Replacement
  1. Sega Genesis Outer Case Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  2. Sega Genesis Outer Case Replacement: adım 2, 1 resimden 1.
    • Flip the Sega Genesis upright.
  3. Sega Genesis Outer Case Replacement: adım 3, 1 resimden 1.
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
  4. Sega Genesis Outer Case Replacement: adım 4, 1 resimden 1.
    • Bend out the LED leads into vertical positions.
  5. Sega Genesis Outer Case Replacement: adım 5, 1 resimden 1.
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
  6. Sega Genesis Outer Case Replacement: adım 6, 1 resimden 1.
    • Separate the main board from the outer case.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Erik Bjornstrom
805 İtibar
3 adet Kılavuz yazıldı
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G29
4 Üyeler
11 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 116
Her zaman: 19,409
