Ana içeriğe geç
Sega Master System II Motherboard Replacement
Neye ihtiyacın var
  1. Sega Master System II Motherboard Replacement, Outer Case: adım 1, 1 resimden 1.
    • Flip the console on its back and unscrew the 5 screws marked on this photo.
  2. Sega Master System II Motherboard Replacement: adım 2, 1 resimden 1.
    • Once you've unscrewed those 5 screws, flip the console upright again.
  3. Sega Master System II Motherboard Replacement: adım 3, 2 resimden 1. Sega Master System II Motherboard Replacement: adım 3, 2 resimden 2.
    • Once the console is upright, first gently pull the rear of the top up.
    • After the top is at an angle, gently remove it by pulling upwards.
    • Note: Be very careful! The top has 2 tabs connecting it with the bottom half, those are in the vincinity of the 2 controller ports! (marked yellow)
  4. Sega Master System II Motherboard Replacement: adım 4, 1 resimden 1.
    • Once the 2 halves are separated, it should look something like this.
  5. Sega Master System II Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Next step is the removal of the RF shield.
    • There are 7 screws in total, please unscrew those.
    • The blue marked screw is shorten than the other 6 screws, this screw has to be put back in the exact same location during reassembly.
    • Note: Tab marked in yellow!
  6. Sega Master System II Motherboard Replacement: adım 6, 1 resimden 1.
    • Carefully lift the RF shield up, left side first.
    • See the note in the previous step.
  7. Sega Master System II Motherboard Replacement: adım 7, 2 resimden 1. Sega Master System II Motherboard Replacement: adım 7, 2 resimden 2.
    • Now we have a complete view of the motherboard, thus coming to the last step.
    • For this step you only need to remove 3 remaining screws.
    • 2 screws on the connector.
    • There's 1 shorter screw as previously with the RF shield. This small screw keeps the voltage regulator in place.
  8. Sega Master System II Motherboard Replacement: adım 8, 1 resimden 1.
    • When you've disassembled everything, it should look like this.
    • Once you've got the replacement board, just follow this guide in reverse order.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Arjan Kuiper
290 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 67
Her zaman: 4,555
