Ana içeriğe geç
Sega Master System Model 2 Disassembly
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sega Master System Model 2 Disassembly, The Case: adım 1, 1 resimden 1.
    • Take out the 5 screws at the bottom
  2. Sega Master System Model 2 Disassembly, RF Shield: adım 2, 1 resimden 1.
    • Remove the 5 screws (3 at the back and 2 on the front)
    • Remove the screw at the side (this screws is different then the other 5 so remember to put them away from the other 5 screws since they are similar)
    • This screw is for the rf shield under for the voltage regulator under this bigger rf shield, its not needed to remove that screw
  3. Sega Master System Model 2 Disassembly, Cartridge Slot: adım 3, 1 resimden 1.
    • Remove the 2 screws thats holding the cartridge slot down
  4. Sega Master System Model 2 Disassembly, The End: adım 4, 1 resimden 1.
    • Congratulations! You have opened your Sega Master System Model 2!
Sonuç
Screenshots taken from a video by Global Garage
3 farklı kişi bu kılavuzu tamamladı.
Krisow
641 İtibar
2 adet Kılavuz yazıldı
3Kılavuz Yorumları
This is in the wrong section.
Owen Ready - Yanıt
Nope, its in the Sega Master System area.
Krisow -
Not a Master System
Chad Luciano - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 51
Her zaman: 2,746
