Ana içeriğe geç
Sega Master System Model 2 Disassembly
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sega Master System Model 2 Disassembly, The Case: adım 1, 1 resimden 1.
    • Take out the 5 screws at the bottom
    FixBot'a Sor
    Yorum Ekle
  2. Sega Master System Model 2 Disassembly, RF Shield: adım 2, 1 resimden 1.
    • Remove the 5 screws (3 at the back and 2 on the front)
    • Remove the screw at the side (this screws is different then the other 5 so remember to put them away from the other 5 screws since they are similar)
    • This screw is for the rf shield under for the voltage regulator under this bigger rf shield, its not needed to remove that screw
    FixBot'a Sor
    Yorum Ekle
  3. Sega Master System Model 2 Disassembly, Cartridge Slot: adım 3, 1 resimden 1.
    • Remove the 2 screws thats holding the cartridge slot down
    FixBot'a Sor
    Yorum Ekle
  4. Sega Master System Model 2 Disassembly, The End: adım 4, 1 resimden 1.
    • Congratulations! You have opened your Sega Master System Model 2!
    FixBot'a Sor
    Yorum Ekle
Sonuç
Screenshots taken from a video by Global Garage
3 farklı kişi bu kılavuzu tamamladı.
Krisander 1998
668 İtibar
2 adet Kılavuz yazıldı
3Kılavuz Yorumları
This is in the wrong section.
Owen Ready - Yanıt Paylaş
Nope, its in the Sega Master System area.
Krisander 1998 - Yanıt Paylaş
Not a Master System
Chad Luciano - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 47
Her zaman: 3,712
