Ana içeriğe geç
Sega Saturn Battery Replacement
Neye ihtiyacın var
  1. Sega Saturn Battery Replacement, Battery: adım 1, 2 resimden 1. Sega Saturn Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
  2. Sega Saturn Battery Replacement: adım 2, 3 resimden 1. Sega Saturn Battery Replacement: adım 2, 3 resimden 2. Sega Saturn Battery Replacement: adım 2, 3 resimden 3.
    • Push up the edge of the battery with the iFixit opening tool to get the battery out of its socket.
  3. Sega Saturn Battery Replacement: adım 3, 3 resimden 1. Sega Saturn Battery Replacement: adım 3, 3 resimden 2. Sega Saturn Battery Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the ESD safe tweezers to pull the battery out of its slot.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jan Ulloa
630 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Leahy Fall 2019 USF Tampa, Team S1-G6, Leahy Fall 2019 üyesi
USFT-LEAHY-F19S1G6
3 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
Japanese Saturn? Here's how to set English after battery replacement...
Turn on the console without a disc inside.
If you get the date/time set screen, press the right direction until you have highlighted the bottom-right symbol then press A.
In the main system menu, select the icon that looks like a box with up-down arrow inside.
Next screen, choose bottom-right option.
In the next menu, select the item in the center (it’s the 2nd option)
Pick English (is not kanji) then select Exit.
Andy Craig - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 57
Son 30 gün: 310
Her zaman: 11,697
