Ana içeriğe geç
Segway Ninebot Max Front Tire Repacement
Neye ihtiyacın var
  1. Segway Ninebot Max Front Tire Repacement, Front Tire: adım 1, 3 resimden 1. Segway Ninebot Max Front Tire Repacement, Front Tire: adım 1, 3 resimden 2. Segway Ninebot Max Front Tire Repacement, Front Tire: adım 1, 3 resimden 3.
    • Before beginning the guide make sure the scooter is off and placed on a stand or table for easier access to work on.
    • Remove the cap and reflection tag using a slotted screwdriver.
  2. Segway Ninebot Max Front Tire Repacement: adım 2, 3 resimden 1. Segway Ninebot Max Front Tire Repacement: adım 2, 3 resimden 2. Segway Ninebot Max Front Tire Repacement: adım 2, 3 resimden 3.
    • Use 3 mm Allen key to loosen three hexagon screws from each side of the wheel.
  3. Segway Ninebot Max Front Tire Repacement: adım 3, 2 resimden 1. Segway Ninebot Max Front Tire Repacement: adım 3, 2 resimden 2.
    • Snap the covers away from the scooter from both sides.
    • Remove the covers slowly and steadily to avoid breaking it.
  4. Segway Ninebot Max Front Tire Repacement: adım 4, 2 resimden 1. Segway Ninebot Max Front Tire Repacement: adım 4, 2 resimden 2.
    • To detach the brake, use a 10 mm Allen wrench to remove the bolt from the tire that is attached with the brake.
  5. Segway Ninebot Max Front Tire Repacement: adım 5, 2 resimden 1. Segway Ninebot Max Front Tire Repacement: adım 5, 2 resimden 2.
    • Use a 15 mm socket wrench to remove 15mm bolt from the tire of the scooter on both sides of the front wheel.
  6. Segway Ninebot Max Front Tire Repacement: adım 6, 1 resimden 1.
    • Pull down the tire and remove it from the frame.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 37
Son 30 gün: 200
Her zaman: 10,137
