Ana içeriğe geç
Hoverboard Bluetooth Remote Control Replacement
Neye ihtiyacın var
  1. Hoverboard Bluetooth Remote Control Replacement, Bluetooth Remote Control: adım 1, 1 resimden 1.
    • Remove the 10 screws with a Phillips screwdriver to access the inside of the hoverboard.
    • The electronic circuit boards are mirrored on both sides, so examine them both to determine which has the Bluetooth setup.
  2. Hoverboard Bluetooth Remote Control Replacement: adım 2, 1 resimden 1.
    • Unhook the lighting and indicator light wires to remove the cover.
  3. Hoverboard Bluetooth Remote Control Replacement: adım 3, 1 resimden 1.
    • Remove the 4 screws that hold the circuit board support.
  4. Hoverboard Bluetooth Remote Control Replacement: adım 4, 1 resimden 1.
    • Remove the 4 screws that secure the board to the support.
  5. Hoverboard Bluetooth Remote Control Replacement: adım 5, 1 resimden 1.
    • Remember the sequence of wires to be soldered on the Bluetooth board.
  6. Hoverboard Bluetooth Remote Control Replacement: adım 6, 1 resimden 1.
    • Use a soldering iron to affix the 4 pins of the Bluetooth board onto the hoverboard board
    • Before soldering the boards, check the functionality of the Bluetooth board by merely inserting the pins, which is enough.
Sonuç
To reassemble your device, Follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
it en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Smilzo
11.267 İtibar
39 adet Kılavuz yazıldı
4 Yorum
Hello! Would it be possible to know where to get that bluetooth module? I would like to try that one my hoverboard but cant find the needed part.
Nix Mathy - Yanıt
Ciao,puoi cercare su EBay AliExpress Wish ed altri store cinesi
Smilzo -
Well after 5 days of search on ali.. ebay.. bangood.. amazon. I still haven't found the good part.
I've ask a lots of sellers and they all replied the module they sell is only for music no app control :(
Nix Mathy -
Nix Mathy devi cercare bene come parola chiave.io li vedo su tanti store
telecomando self balance hoverboard
https://www.amazon.it/Hoverboard-Telecom...
https://www.ebay.it/itm/REPLACEMENT-REMO...
Smilzo -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 1,111
