Ana içeriğe geç
Sennheiser HD 4.50 Headband Pad Replacement
Neye ihtiyacın var
  1. Sennheiser HD 4.50 Headband Pad Replacement, Headband Pad: adım 1, 2 resimden 1. Sennheiser HD 4.50 Headband Pad Replacement, Headband Pad: adım 1, 2 resimden 2.
    • Extend the headphones by pulling the headband away from the base of the headphones.
    • Do this to both the right and left sides of the headphones.
  2. Sennheiser HD 4.50 Headband Pad Replacement: adım 2, 3 resimden 1. Sennheiser HD 4.50 Headband Pad Replacement: adım 2, 3 resimden 2. Sennheiser HD 4.50 Headband Pad Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the two screws on the silver piece on either edge of the headband.
    • Make sure to do this to both the right and left sides of the headphones.
    • After removing the screws, slide both silver pieces down.
  3. Sennheiser HD 4.50 Headband Pad Replacement: adım 3, 2 resimden 1. Sennheiser HD 4.50 Headband Pad Replacement: adım 3, 2 resimden 2.
    • Grasp the headband pad firmly with your pointer finger and thumb and gently pull the pad away from the headband until the pad is fully removed.
    • You may need to apply adhesive when sticking the replacement headband pad back to the headband.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Grace Singley
595 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
Is there any guide on replacing the hinge that the ear cups are connected to?
Keoabetswe Morake - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 93
Her zaman: 2,526
