Giriş
one of the most common ways a pair of headphones brakes is the wires get flexed to much near the stereo jack and brake one of the 3-4 wires causing one or both of the speakers to "fail" you can save yourself $100+ with a dollar store patch cable and some solder
Neye ihtiyacın var
First find the place where the wire is broken inside the rubber coating you can find the spot usaly by moving the cable around while playing music to see at what spot it makes sound or doesn't for this guide i will take the most commonly broken spot, just above the jack.
do the same to the patch cable if it has rubber sheleding just strip off about 0.25"
to find the right wires (color codes are different depending on the manufacturer):
take a multimeter and set it to resistance (or contanuity if you have a fancy one)
put one probe on the sleeve(the biggest part of of the 3.5 mm plug (the ground) and try each wire in turn with the other probe to find it
next repeat the process with the tip of the plug (the left channel)
the last wire (if you have 3) will be the right channel
you may have a 4th wire this is a seccond ground wire
once it works properly
put the 2 cables paralel to each other and one of the wires down make sure its not touching any other exposed wire
wrap electrical tape around once
put a second wire down wrap it a second time with tape
bend one of the cables to face the other direction and the last wire down
wrap it 3-4 more times to make it sealed well or use heat shrink tubeing if you have it
Bir başkası bu kılavuzu tamamladı.
