Ana içeriğe geç
Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement
Neye ihtiyacın var
  1. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Earmuff: adım 1, 1 resimden 1.
    • Grab the earmuffs with one hand and hold the headphones with the other.
  2. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: adım 2, 1 resimden 1.
    • Pull the earmuff until it separates from headphones as shown.
  3. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Charging Port/Volume Control: adım 3, 2 resimden 1. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Charging Port/Volume Control: adım 3, 2 resimden 2.
    • After removing the muffs, the speaker cover must be removed by unscrewing 4 3mm Phillips screws using a #000 Phillips screwdriver.
  4. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: adım 4, 1 resimden 1.
    • After locating the circuit board that contains the charging port as well as the volume control dial, two 3 mm screws must be removed using a #000 phillips screwdriver.
  5. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: adım 5, 1 resimden 1.
    • Unplug the blue ribbon attaching the circuit board to the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
welsayed
319 İtibar
3 adet Kılavuz yazıldı
2 Yorum
where do I get the replacement module?
Jan G - Yanıt
Have you found one yet? I've needed to do this repair for a while.
Paul B -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 64
Her zaman: 397
