Ana içeriğe geç
Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement
Neye ihtiyacın var
  1. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement, Earmuff: adım 1, 1 resimden 1.
    • Grab the earmuffs with one hand and hold the headphones with the other.
  2. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: adım 2, 1 resimden 1.
    • Pull the earmuff until it separates from headphones as shown.
  3. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Remove the 4 8mm screws with a #000 Philips screw driver.
  4. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the 2 2mm screws using a #000 phillips screwdriver.
  5. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: adım 5, 1 resimden 1.
    • Using a soldering iron, remove all the wires attached to the motherboard and other components.
  6. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Finally, remove the blue ribbon plugged into the motherboard.
    • Make sure to do this using tweezers, so as to avoid any damage to the fragile ribbon.
Sonuç
nasaintj
159 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 63
Her zaman: 311
