Ana içeriğe geç
Separating Main Board
Neye ihtiyacın var
  1. Separating Main Board, Remove Battery: adım 1, 3 resimden 1. Separating Main Board, Remove Battery: adım 1, 3 resimden 2. Separating Main Board, Remove Battery: adım 1, 3 resimden 3.
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
    FixBot'a Sor
    Yorum Ekle
  2. Separating Main Board, Remove Trigger Buttons: adım 2, 2 resimden 1. Separating Main Board, Remove Trigger Buttons: adım 2, 2 resimden 2.
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
    FixBot'a Sor
    Yorum Ekle
  3. Separating Main Board, Remove Screws: adım 3, 2 resimden 1. Separating Main Board, Remove Screws: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
    FixBot'a Sor
    Yorum Ekle
  4. Separating Main Board, Unclip Covers: adım 4, 3 resimden 1. Separating Main Board, Unclip Covers: adım 4, 3 resimden 2. Separating Main Board, Unclip Covers: adım 4, 3 resimden 3.
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
    FixBot'a Sor
    Yorum Ekle
  5. Separating Main Board, Separate Covers: adım 5, 1 resimden 1.
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  6. Separating Main Board, Remove Ribbon Cable: adım 6, 3 resimden 1. Separating Main Board, Remove Ribbon Cable: adım 6, 3 resimden 2. Separating Main Board, Remove Ribbon Cable: adım 6, 3 resimden 3.
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
    FixBot'a Sor
    Yorum Ekle
  7. Separating Main Board, Remove Screws: adım 7, 3 resimden 1. Separating Main Board, Remove Screws: adım 7, 3 resimden 2. Separating Main Board, Remove Screws: adım 7, 3 resimden 3.
    • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
    • Six 10.1mm screws
    • One 5.8mm screws
    FixBot'a Sor
    Yorum Ekle
  8. Separating Main Board, Separate Main Board: adım 8, 3 resimden 1. Separating Main Board, Separate Main Board: adım 8, 3 resimden 2. Separating Main Board, Separate Main Board: adım 8, 3 resimden 3.
    • Slide the R buttons up and off its peg.
    • Slide the L button up and off its peg.
    • Remove the main board by rotating it towards the USB-C port. Then lift it out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brian W
1.800 İtibar
8 adet Kılavuz yazıldı
1Rehber Yorum
if you need a replacement ribbon the specs are
length: 70mm
pitch: 0.5mm
pins: 20
forward side pinning (that means the contacts are on the same side)
some listings add the total width, thats 20.5mm
Max R. - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 28
Her zaman: 1,175
