Ana içeriğe geç
Separating Rear Board
Neye ihtiyacın var
  1. Separating Rear Board, Remove Battery: adım 1, 3 resimden 1. Separating Rear Board, Remove Battery: adım 1, 3 resimden 2. Separating Rear Board, Remove Battery: adım 1, 3 resimden 3.
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. Separating Rear Board, Remove Trigger Buttons: adım 2, 2 resimden 1. Separating Rear Board, Remove Trigger Buttons: adım 2, 2 resimden 2.
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. Separating Rear Board, Remove Screws: adım 3, 2 resimden 1. Separating Rear Board, Remove Screws: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. Separating Rear Board, Unclip Covers: adım 4, 3 resimden 1. Separating Rear Board, Unclip Covers: adım 4, 3 resimden 2. Separating Rear Board, Unclip Covers: adım 4, 3 resimden 3.
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. Separating Rear Board, Separate Covers: adım 5, 1 resimden 1.
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. Separating Rear Board, Remove Ribbon Cable: adım 6, 3 resimden 1. Separating Rear Board, Remove Ribbon Cable: adım 6, 3 resimden 2. Separating Rear Board, Remove Ribbon Cable: adım 6, 3 resimden 3.
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. Separating Rear Board, Remove Caps: adım 7, 2 resimden 1. Separating Rear Board, Remove Caps: adım 7, 2 resimden 2.
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  8. Separating Rear Board, Remove Screws: adım 8, 3 resimden 1. Separating Rear Board, Remove Screws: adım 8, 3 resimden 2. Separating Rear Board, Remove Screws: adım 8, 3 resimden 3.
    • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
    • Four around the Right stick
    • Four around the Left stick
    • One next to the Battery connector
  9. Separating Rear Board, Separate Rear Board: adım 9, 3 resimden 1. Separating Rear Board, Separate Rear Board: adım 9, 3 resimden 2. Separating Rear Board, Separate Rear Board: adım 9, 3 resimden 3.
    • Pull the two rumble motors out of their housings.
    • Grab the analog sticks to pull out the circuit board
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brian W
1.692 İtibar
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 551
