Ana içeriğe geç
Seville Classics MSC10166 Buttons Replacement
Neye ihtiyacın var
  1. Seville Classics MSC10166 Buttons Replacement, PCB (Printed Circuit Board): adım 1, 1 resimden 1.
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  2. Seville Classics MSC10166 Buttons Replacement: adım 2, 1 resimden 1.
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
    FixBot'a Sor
    Yorum Ekle
  3. Seville Classics MSC10166 Buttons Replacement: adım 3, 1 resimden 1.
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
    FixBot'a Sor
    Yorum Ekle
  4. Seville Classics MSC10166 Buttons Replacement: adım 4, 1 resimden 1.
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
    FixBot'a Sor
    Yorum Ekle
  5. Seville Classics MSC10166 Buttons Replacement: adım 5, 2 resimden 1. Seville Classics MSC10166 Buttons Replacement: adım 5, 2 resimden 2.
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
    FixBot'a Sor
    Yorum Ekle
  6. Seville Classics MSC10166 Buttons Replacement, Buttons: adım 6, 1 resimden 1.
    • Remove the two 8 mm screws that attach the buttons to the top cover of the fan.
    FixBot'a Sor
    Yorum Ekle
  7. Seville Classics MSC10166 Buttons Replacement: adım 7, 1 resimden 1.
    • Remove the buttons from the top cover.
    FixBot'a Sor
    Yorum Ekle
  8. Seville Classics MSC10166 Buttons Replacement: adım 8, 1 resimden 1.
    • Wipe down any dirt on the buttons.
    FixBot'a Sor
    Yorum Ekle
  9. Seville Classics MSC10166 Buttons Replacement: adım 9, 1 resimden 1.
    • Wipe down the frame that holds the buttons.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Queena Phung
114 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-46, Forte Fall 2012 Cal Poly, Team 15-46, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G46
5 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
Rick - Yanıt Paylaş
Is there a way to keep the fan in ALWAYS ON position. So I can control it’s ON/OFF using a smart plug?
Vish Talreja - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 50
Her zaman: 4,766
