Ana içeriğe geç
Sew a Ladder Stitch
Neye ihtiyacın var
  1. Sew a Ladder Stitch, Sew a Ladder Stitch: adım 1, 3 resimden 1. Sew a Ladder Stitch, Sew a Ladder Stitch: adım 1, 3 resimden 2. Sew a Ladder Stitch, Sew a Ladder Stitch: adım 1, 3 resimden 3.
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
  2. Sew a Ladder Stitch: adım 2, 2 resimden 1. Sew a Ladder Stitch: adım 2, 2 resimden 2.
    • Take a small stitch, going in and out of the material, on one side of the tear only.
  3. Sew a Ladder Stitch: adım 3, 2 resimden 1. Sew a Ladder Stitch: adım 3, 2 resimden 2.
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
  4. Sew a Ladder Stitch: adım 4, 2 resimden 1. Sew a Ladder Stitch: adım 4, 2 resimden 2.
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
  5. Sew a Ladder Stitch: adım 5, 3 resimden 1. Sew a Ladder Stitch: adım 5, 3 resimden 2. Sew a Ladder Stitch: adım 5, 3 resimden 3.
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
90.418 İtibar
142 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 29
Son 30 gün: 173
Her zaman: 13,522
