Ana içeriğe geç
Sew a Straight Stitch
Neye ihtiyacın var
  1. Sew a Straight Stitch, Sew a Straight Stitch: adım 1, 2 resimden 1. Sew a Straight Stitch, Sew a Straight Stitch: adım 1, 2 resimden 2.
    • Thread your needle and tie a knot in the end of the thread.
    • We're using contrasting thread for visibility, but when you do your repair you will want to use matching thread.
    • Drive the needle through the back of the bottom material.
    • Pull the thread taut.
    FixBot'a Sor
    Yorum Ekle
  2. Sew a Straight Stitch: adım 2, 2 resimden 1. Sew a Straight Stitch: adım 2, 2 resimden 2.
    • Drive the needle through the back side of the top material.
    • In this case we're sewing a buckle, but you can use this stitch to sew just about anything together.
    • Align the two materials in their final position.
    FixBot'a Sor
    Yorum Ekle
  3. Sew a Straight Stitch: adım 3, 2 resimden 1. Sew a Straight Stitch: adım 3, 2 resimden 2.
    • Drive the needle down through both layers of material, coming out on the back side of the bottom material. Push the needle out of the material.
    • The closer you drive the needle in to where the thread came up, the smaller the stitch length. Having a smaller stitch length requires more stitches, but creates a stronger seam.
    FixBot'a Sor
    Yorum Ekle
  4. Sew a Straight Stitch: adım 4, 2 resimden 1. Sew a Straight Stitch: adım 4, 2 resimden 2.
    • Ensure the two layers are correctly aligned.
    • Drive the needle through both layers of fabric from the back side of the bottom material, coming up on the top side of the top material.
    FixBot'a Sor
    Yorum Ekle
  5. Sew a Straight Stitch: adım 5, 3 resimden 1. Sew a Straight Stitch: adım 5, 3 resimden 2. Sew a Straight Stitch: adım 5, 3 resimden 3.
    • Continue sewing through both layers, going down from the top and up from the bottom, as described in steps 3 and 4 of this guide.
    • When you come to the end of your material, draw the needle in between the two layers of material, under the thread of the closest stitch.
    • Slowly start to pull the thread taut. As you pull a loop will form.
    • Draw the needle through the loop and pull the thread taut.
    • Repeat the process of drawing the needle between the layers, creating a loop, and drawing the needle through the loop as described in this step.
    FixBot'a Sor
    Yorum Ekle
  6. Sew a Straight Stitch: adım 6, 1 resimden 1.
    • Cut any remaining thread and admire your work.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
90.929 İtibar
142 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 35
Son 30 gün: 118
Her zaman: 5,189
