Ana içeriğe geç
Sew-on Patch
Neye ihtiyacın var
  1. Sew-on Patch, Sew-on Patch: adım 1, 2 resimden 1. Sew-on Patch, Sew-on Patch: adım 1, 2 resimden 2.
    • Examine the damage. Clip any loose threads and remove any debris from the tear.
    • Grab a trendy patch.
    FixBot'a Sor
    Yorum Ekle
  2. Sew-on Patch: adım 2, 2 resimden 1. Sew-on Patch: adım 2, 2 resimden 2.
    • Position the patch over the hole.
    • Any patch you use should overlap the damage by at least 1/8".
    FixBot'a Sor
    Yorum Ekle
  3. Sew-on Patch: adım 3, 3 resimden 1. Sew-on Patch: adım 3, 3 resimden 2. Sew-on Patch: adım 3, 3 resimden 3.
    • Pin the patch to the jeans.
    • Be sure to only pin the patch to one layer of denim, or you will sew the pants shut.
    FixBot'a Sor
    Yorum Ekle
  4. Sew-on Patch: adım 4, 3 resimden 1. Sew-on Patch: adım 4, 3 resimden 2. Sew-on Patch: adım 4, 3 resimden 3.
    • Slide the jeans into the sewing machine, positioning the needle over the edge of the patch.
    • Be sure you only have one layer of the jeans between the needle and the sewing machine arm, or you will sew the pants shut.
    FixBot'a Sor
    Yorum Ekle
  5. Sew-on Patch: adım 5, 2 resimden 1. Sew-on Patch: adım 5, 2 resimden 2.
    • Lower the pressor foot.
    • Sew along the edge of the patch.
    • Remove the pins before you get to them.
    • Sewing over a pin can bend or break the needle.
    FixBot'a Sor
    Yorum Ekle
  6. Sew-on Patch: adım 6, 2 resimden 1. Sew-on Patch: adım 6, 2 resimden 2.
    • Continue sewing around the patch, lifting the pressor foot to turn at corners of the patch.
    FixBot'a Sor
    Yorum Ekle
  7. Sew-on Patch: adım 7, 3 resimden 1. Sew-on Patch: adım 7, 3 resimden 2. Sew-on Patch: adım 7, 3 resimden 3.
    • When you come all the way around, overlap the first two or three stitches.
    • Lift the needle and pressor foot.
    • Slide the jeans out of the sewing machine.
    • Clip any threads, and admire your work.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
90.914 İtibar
142 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.511 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 115
Her zaman: 10,291
