Ana içeriğe geç
Sewing a small Hole for a Seamless Fix
Neye ihtiyacın var
  1. Sewing a small Hole for a Seamless Fix, Sewing a small Hole for a Seamless Fix: adım 1, 1 resimden 1.
    • Ensure the hole is small enough to be easily repaired with sewing.
  2. Sewing a small Hole for a Seamless Fix: adım 2, 2 resimden 1. Sewing a small Hole for a Seamless Fix: adım 2, 2 resimden 2.
    • Thread the needle with a length of thread doubling it over at the end to secure it.
    • At a good length (depending on the size of the hole), cut off the excess and tie a knot at the end of the thread.
  3. Sewing a small Hole for a Seamless Fix: adım 3, 1 resimden 1.
    • Position the sweater with the hole facing up on a flat surface. Make sure your sweater is inside out.
    • This will make the stitches not as visible.
  4. Sewing a small Hole for a Seamless Fix: adım 4, 3 resimden 1. Sewing a small Hole for a Seamless Fix: adım 4, 3 resimden 2. Sewing a small Hole for a Seamless Fix: adım 4, 3 resimden 3.
    • Insert the needle into the fabric slightly above the hole, pulling it through the backside of the sweater, and repeat this process along the edges of the hole to create a series of stitches.
  5. Sewing a small Hole for a Seamless Fix: adım 5, 1 resimden 1.
    • Continue stitching back and forth across the hole in a zig-zag pattern until it is completely closed, ensuring stitches are tight and secure.
  6. Sewing a small Hole for a Seamless Fix: adım 6, 2 resimden 1. Sewing a small Hole for a Seamless Fix: adım 6, 2 resimden 2.
    • Tie off the thread by creating a small knot at the end of the stitching and trimming any excess thread with scissors.
  7. Sewing a small Hole for a Seamless Fix: adım 7, 1 resimden 1.
    • Reverse your sweater outside in. Tug at the area slightly to ensure the stitches hold and the fabric remains intact.
Bitiş Çizgisi
Kendra Tejada
145 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 146
