Ana içeriğe geç
Shakespeare Synergy Steel Titanium Fishing Reel Disassembly
Neye ihtiyacın var
  1. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly, Fishing Reel: adım 1, 1 resimden 1.
    • Remove spool cover.
  2. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly, reel: adım 2, 1 resimden 1.
    • Take off bottom cover, there is a small screw in the front of the cover. After that's removed just rotate clockwise to remove.
  3. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: adım 3, 1 resimden 1.
    • Remove release handle. There is a little pin in the place that is circled. It will need to be hit out with a tiny screwdriver and hammer. After that the handle will slide right out.
  4. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: adım 4, 1 resimden 1.
    • The spring circled needs to be removed with a flat head screw driver of a small pair of pliers. after that is removed the spool topper will fall right out. Also unscrew the reel handle (what's used to reel in the line).
  5. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: adım 5, 1 resimden 1.
    • Next, take off the snap on clip on the top and pull off the spool. Be sure to keep track of the order of the washers both plastic and metal.
  6. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: adım 6, 2 resimden 1. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: adım 6, 2 resimden 2.
    • Remove this center gear. Keep the alignment of the gears the same when you take it off.
  7. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: adım 7, 1 resimden 1.
    • Remove the crank shaft with the four screws that hold it in. Be sure that the alignment of the pins on the back side stay the same with the smallest pin facing down.
  8. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: adım 8, 1 resimden 1.
    • Next, remove the pinion gear that was sitting ion the area circled in red. Easily removed with pliers.
  9. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: adım 9, 1 resimden 1.
    • Remove the drag adjustment wheel by taking off the snap ring with a flat head screwdriver.
  10. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: adım 10, 1 resimden 1.
    • Finally, remove the center bearing. It is removed easiest by pushing two screwdrivers outwards on the inside of the bearing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Coen Herring
211 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 43
Her zaman: 795
