Ana içeriğe geç
Shark Apex DuoClean Powered Lift-Away AZ1002 HEPA Filter Replacement
  1. Shark Apex DuoClean Powered Lift-Away AZ1002 HEPA Filter Replacement, HEPA Filter: adım 1, 1 resimden 1.
    • Pull on the lower lip to release the HEPA filter cover.
    • Pull the cover away from the vacuum, allowing the top of the cover to slide downward out of it's slot.
  2. Shark Apex DuoClean Powered Lift-Away AZ1002 HEPA Filter Replacement: adım 2, 2 resimden 1. Shark Apex DuoClean Powered Lift-Away AZ1002 HEPA Filter Replacement: adım 2, 2 resimden 2.
    • Use the center black plastic handle to pull the filter horizontally outward.
  3. Shark Apex DuoClean Powered Lift-Away AZ1002 HEPA Filter Replacement: adım 3, 2 resimden 1. Shark Apex DuoClean Powered Lift-Away AZ1002 HEPA Filter Replacement: adım 3, 2 resimden 2.
    • Rinse the filter under cold water to remove the dirt.
  4. Shark Apex DuoClean Powered Lift-Away AZ1002 HEPA Filter Replacement: adım 4, 1 resimden 1.
    • Allow filter to air-dry completely before reinstalling it in the vacuum.
    • If filter is not left to dry for long enough, lingering water in the filter can be dawn into electric parts of the vacuum.
Sonuç
To reassemble your device, follow these instructions in reverse order. When replacing the HEPA filter cover be sure to insert the top of the filter into position first, before clicking the rest of the filter into place.
Roslyn :D
247 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 55
