Ana içeriğe geç
Shark Cordless Pet Perfect Front Motor Replacement
Neye ihtiyacın var
  1. Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: adım 1, 2 resimden 1. Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: adım 1, 2 resimden 2.
    • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
  2. Shark Cordless Pet Perfect Front Motor  Replacement: adım 2, 3 resimden 1. Shark Cordless Pet Perfect Front Motor  Replacement: adım 2, 3 resimden 2. Shark Cordless Pet Perfect Front Motor  Replacement: adım 2, 3 resimden 3.
    • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
  3. Shark Cordless Pet Perfect Front Motor  Replacement: adım 3, 3 resimden 1. Shark Cordless Pet Perfect Front Motor  Replacement: adım 3, 3 resimden 2. Shark Cordless Pet Perfect Front Motor  Replacement: adım 3, 3 resimden 3.
    • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
  4. Shark Cordless Pet Perfect Front Motor  Replacement: adım 4, 2 resimden 1. Shark Cordless Pet Perfect Front Motor  Replacement: adım 4, 2 resimden 2.
    • Remove the belt from the motor mount, and then replace with a new belt.
  5. Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: adım 5, 2 resimden 1. Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: adım 5, 2 resimden 2.
    • Remove the solder from both motor terminals.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ashley Calkins
560 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Blackwell Spring 2017 USF Tampa, Team 16-2, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G2
4 Üyeler
11 adet Kılavuz yazıldı
2 Yorum
Well done, Ashley! You might want to note that using a solder remover is helpful.
Jimbo - Yanıt
Where can I obtain the new motor with the plastic gear?
F V - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 2,665
