Giriş
If your vacuum is leaving behind debris or has loss of suction, use this guide to replace the brushrolls. You will not need any tools to replace the brushrolls.
Press the two Brush Roll Access buttons down at the same time to detach the cover.
Pull the cover off of the vacuum by lifting it up.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I need help with removing the beater bar on the nv835 I can't find help nowhere
