Ana içeriğe geç
Shark DuoClean Powered Lift-Away Speed Brushroll Replacement
  1. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement, Brushroll: adım 1, 3 resimden 1. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement, Brushroll: adım 1, 3 resimden 2. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement, Brushroll: adım 1, 3 resimden 3.
    • Press the two Brush Roll Access buttons down at the same time to detach the cover.
    • Pull the cover off of the vacuum by lifting it up.
  2. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: adım 2, 2 resimden 1. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: adım 2, 2 resimden 2.
    • Pull up on the Pull Tab to remove the large brush roll.
  3. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: adım 3, 2 resimden 1. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: adım 3, 2 resimden 2.
    • Press the Eject Roller button to detach the small roller.
    • Pull the roller away from the vacuum to remove it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Catie Halvorsen
699 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G4, White Fall 2018 Cal Poly, Team S17-G4, White Fall 2018 üyesi
CPSU-WHITE-F18S17G4
4 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
I need help with removing the beater bar on the nv835 I can't find help nowhere
Ethel McClintock - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 107
Son 30 gün: 515
Her zaman: 33,579
